Squeaky springs
Gval900
Hello, I purchased a Vintage Cruiser that is a few years old. My complaint is that something underneath squeaks with any movement. For example: if we go in the door. If I rock the coach side to side, if I go over bumps or make turns. I have put oil on the leaf springs and on the connecting bolts. Nothing.
Oil was a mistake. it collects dirt which then acts as an abrasive lubricated by the oil. I would check all the rubber bushings, sway bar ,etc.
There are several areas that can squeak on a spring pack.
You might start by trying Eaton's recommendation for a new spring pack here. Granted your spring are not new but this is a good first step.
If you are handy you can always rebuild them
Here is a video that points out some leaf spring components that keep the spring pack quiet
