- Nov 9, 2019
- St. Augustine Fl
- Canyon Star 3710
- 2017 Gmc Terrain & 2017 Chevrolet Colorado ZR-2
Here at the house, I have an RV Port under which I keep my coach parked. I have it hooked to a 20 amp service breaker, in my pool shed. The outdoor temperatures here have ranged from a low of about 18, up to 60+ degrees.
First question: Should I leave my refrigerator on while basically in storage? Other than using electricity, what are the "pros & cons"? I have been leaving it on, but set in a low position.
Second question: I have a small 1200 watt electric heater with a thermostat, which I have been leaving on, & depending on outside temperature, temps inside the coach stay between 45-62 degrees. So, by having the heater running, what effect, if any, does the heater being on have upon the humidity inside the coach? I've seen no sweating of windows, nor indications of moisture inside. I just want to do whatever is best for the coach!
