Hello everyone. Got 1983 Brave with 454 cid engine. Have redone radiator. Replace hoses and belts. New water pump, alternator, and fuel pump and fuel filter and new hot batter with new cables. Cleaned and primed carb and it started like brand new. Backed it up to test brakes out of shop. Now her puzzle. I swear all I did was replace wires on floor high beam switch. After that all it does when you turn key is nothing. Dash lights come on but no started sound. Had starter bench tested. Checked OK. It’s been setting 15 years and squirrels have had a field day with wiring but just changing out chewed up high beam switch wires could cause this!? Help if you can. Thanks. BTW-replace solenoid in battery box.
