Temperature sensor error message on Firefly (Roadtrek Zion Slumber)
LawrenceSolomon
I have a 2021 Roadtrek Zion Slumber. The Firefly unit is showing an interior temperature of 124 degrees (only 75 degrees outside today.) And there is a "Temp Sensor Error" message. The climate control system is working fine. Any ideas? Thank you.
I have a error message as well. I contacted Firefly and was informed I needed an update on firefly and that the temperature sensor error was a known glitch and would go away with the update. Did you get that done?
