Have to convince the betterhalf that the Subaru isn’t up to the task.I don't like those numbers!!!! 10% of 3000 lbs is 300 lbs. if the hitch won't take more than 200lbs then the tow weight should read 2000lbs. Anything under 10% toung weight is asking for the " tail wagging the dog" effect and is dangerous.
Kevin is spot on! The numbers don't look good to me either.I don't like those numbers!!!! 10% of 3000 lbs is 300 lbs. if the hitch won't take more than 200lbs then the tow weight should read 2000lbs. Anything under 10% toung weight is asking for the " tail wagging the dog" effect and is dangerous.
Just one thought. the suspension is the problem. An equalizer hitch would make the toung weight problem go away.Have to convince the betterhalf that the Subaru isn’t up to the task.
