Kevin D Pem
RVF 1K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
election audit, MaricopaWhat audit? IRS set up out there? Since when is the Bureau Of Land Management and ANTIFA joined up?
It's been moved again to the Trip Planning forum. If this triggers any heat related to politics, election, etc. it's going private or going away.I see you moved this. I would like to remind you there are Travelers that read this forum that should also get this important information
Only in very small portions of the country. We are going to be traveling from Texas thru Colorado, Utah, Idaho, Washington, and Montana. The most direct routes are thru major cities, which even when there is no concern for "bad actors" the travel is less than desirable. I really detest driving a large bus towing thru a major rush hour traffic.Sad that trip planning in the USA is like trip planning in a Banana Republic...................................
Absolutely. Hit those country roads, I need to avoid traffic and stress as well when traveling. I mostly drive over nights and sleep during the day. Sucks whenever I have to get up to do something before 10am but I like the 1300-0420 sleep pattern. It puts me on an overlap of most peoples schedules but I tend to be less stressed in dealing with others during those times.Only in very small portions of the country. We are going to be traveling from Texas thru Colorado, Utah, Idaho, Washington, and Montana. The most direct routes are thru major cities, which even when there is no concern for "bad actors" the travel is less than desirable. I really detest driving a large bus towing thru a major rush hour traffic.
The scenic routes offer much better views. In addition, the scenic routes allow my stress level to remain low, so that I am enjoyable to be around.
When trip planning for RV travels, very rarely do you need the fastest, most direct route. Enjoy the journey!
