vin number
georgetown 374
Hello from Europe .. I'm looking for a VIN number, where is it located? and the engine too? .. I have Forest river Georgetown 374 2009yr ,,ford V10 .. i think w22 chassis.... very thanks ,,
A quick Google yield "sticker in cabinette over the sink' and another 'a tag in the engine compartment near the oil dipstick'.
The VIN is also located on the tire data tag usually located near the driver’s seat.
Possibly lower left of windshield in the dashboard if it’s an E350 Ford, Or the sticker on the door jamb post?
how to fill the water tank? there are no instructions ..I can't find a tap for the direction of the water. Directly if I connect the connection ... where will the pressure go?
What do you mean tap for the direction of the water?
the water tank is filled from the outside. There is a hookup for a hose. It will say something like “fresh water!” THIS IS DIFFERENT FROM THE STREET HOOKUP!! Be careful not to over fill the tank. Some tanks will not have an overflow pipe inside the RV, so the best case scenario would be to locate the tank (under the dinette bench or possibly behind a closet) and have someone watch as it is being filled, the stored water is then pumped through out the RV as needed. There should be a switch inside that says “pump” or “water pump.” Hope this helps??
