Washing Machine
jagpot
RVF VIP
California
King Aire
Spartan
Cummins
Jeep Wr Sahara
Decided I better do a small load of laundry since we have never used it. We have only had the coach 4 months. On the front of the washing machine is says "warning: make sure drain is open" What exactly does that mean? Do I need to open the grey water valve? I thought you could run the washer while traveling. What about if you do not have dumping abilities?
That note is referring to your gray water drain valve and is intended to prevent overflowing the gray tank. You can use it with the valve closed, but you need to be aware that you cannot do ten loads of laundry without encountering a problem. We recently did four loads without maxing out the gray tank.
Thank you so much. So much to learn and this forum never lets me down!
