My "autofill" is me watching to see when water comes out the overflow hose. ?Okay, on further thought, let's clarify what happens after the house filter.
If you have autofill ON and the fresh tank is not full the water goes to the fresh tank
If you have autofill ON and the fresh tank is full, it goes into the coach
If you have autofill OFF it goes into the coach
This is why if you have autofill on and it's filling your tank you will need to have your water pump ON to get water pressure in the coach. There is also no reason to turn off your water pump although I bet most of us do. If the water pump senses sufficient pressure coming from city water the water pump will not run. Only when the pressure is insufficient at the water pump will it turn on.
