Hello,
I've got a 2018 Kodiak Cub 175BH that I am winterizing for the first time. I was following the process as shown in this YouTube video, switched the heater tank bypass valve and I left the hot water tank plug out. I began to pump anti-freeze through the water lines inside, and when I went out to flush the exterior spray hose, there was a small but steady stream of water (slightly pink) coming out of the water heater tank drain hole. Is that typical? Is the bypass valve possibly not fully closing off the line into the tank? I don't think the antifreeze will hurt the tank right?
