Water Heater Replacement
Carh020157
Replacing our SW6DE water heater however wires from camper are 1 green, 1 green with stripes and 1 white, wires on new water heater are red, green and blue. What wires go to what? HELP PLEASE
I have attached the manual which has the wiring instructions on page 5. You probably need to find out where the wires on the camper go, switch or junction box. Hope this helps.
  • Suburban_Gas_Water_Heater_Manual.pdf
Pull the water heater switch out and check the colors there. match the switch wire with the red wire on water heater. the blue wire in the heater will go to the pilot lite on the switch. the green wire is likely green.
