Limited access from inside through by removing a drawer under the stove one leak found and fixed but still have small leakCan you access the water heater from the inside? Ours is under the Dinette seating and when we had a leak it was loose water line that I just had to tighten up.
Did not solve the problem dont want to have to remove the water heater from outsideThe relief valve will only open when the water is heating (or hot). Thus, when you say (seems to be when water heater is on) it makes me think that might be your problem. My suggestion would be, go outside and open up the water heater cover, turn on the water heater, (watch a good game on TV) and see if you can see some sputtering from the relief valve (or any other source of water). Water heaters on RV occasionally leak on the outside. I can't imagine an RV designer putting a TV below a water heater...BUT! Anyhoo, check the drain valve, the relief valve, and I believe you'll find the culprit. Blessings friend...
