We recently purchased a 2021 Leprechaun 260DS (our first RV). It comes with a Winegard 360+ on the roof and, in theory, is prewired for easy installation of the Winegard GW-1000 gateway. The wiring is concealed in the ceiling below the Winegard 360+ by a small circular cover.
I removed the cover from the ceiling and found the three leads to the Winegard 360+ along with a power wire and a ground wire. The ends of the wires were not stripped and were taped together with black electrical tape. The power wire was yellow with a green stripe. I tested the wires with a multimeter and found they had no voltage. I then took some panels off of the surrounding cabinetry in order to figure out where the power wire went. I found the wire entered the cavity above the cabinet that is to the right as one enters the RV. I confirmed it was the same wire using a continuity tester. The wire, for some reason then returns back to whence it came (above the entry door). From there I don’t know where it goes. From the cavity above the cabinet, it doesn’t go to the fuse box nor does it go to the monitor panel. From that cavity it could have easily gone to either but does not.
One thing to note regarding the monitor panel: there is a slot for “wifi” but it is not populated with a switch or light.
Any thoughts regarding where the yellow/green wire might go or why it does not have any voltage?
I tried to get assistance from CoachNet, Winegard and Coachmen. I contacted CoachNet for assistance and, after being on hold for a long time, requested a callback but they never called back. I also contacted Winegard support via their web site and was redirected to “JustAnswer”. A JustAnswer technician contacted me but, after some discussion, suggested that I contact Coachman. I then reached out to a Coachmen service rep (Jason Johnson) but he *never* responded to my request. Service and support apparently SUUUUCKS in the RV industry.
Thanks for any help,
Richard
Richard
