crow3051
- Jan 31, 2021
- Forest river
- Wildwood-hg
We bought a micro mini winnie 2108 fbs September of 22 brand new. Stayed in it overnight at the dealership and had a water leak under kitchen sink, the refrigerator door top plastic cover and awning wiring cover come off. The dealership fixed them. One week later after driving camper 149 miles, put the black water flush on the water port and turned on. Water was instantly coming out of the bottom of the camper. Took off port and tightened it. No more leak. Front inside speaker motor working, loose pin. Hwt stopped heating up in one month after purchase, fixed it. Three months, leak in slideout. Dealer had to fix leak and damaged wood. Drawer is under stove came off track. Stove handle lights quit working. Six months, 12 v battery def. Nine months, seal around main window coming off. One year-squeaky awning, bathroom door. 14 months, awning comes in at a snails pace on 110v. Camper 12v system not working. Redo grounds on frame and exposed fuses on frame. 16 months-spray foam under camper missing and laminate backsplash coming off. Dinette table delaminated, manufacturer replaced. Water leaks under sink from hot water hose and 12v pump. Manufacturer sent us new pump. 20 months-Front jack stopped working, exposed 30a fuse on frame. Corroded. Bought new one and relocated. All kinds of other little problems. This is mostly a Winnebago problem, not the manufacturer of the componentsSub par manufacturing.
