Good evening and Thanks for the opportunity to join.
Has anyone installed an aftermarket leveling kit on the Wolfpack models, specifically the Wolfpack 365pack16?
Looking forward to your experienced responses.
I'm guessing you need to lift the trailer to match your truck? Couple of things come to mind, and that is to make a sub structure to fit between the suspension mounts and the frame, second is to make sure you aren't going to be over height when you are done. What does the leveling kit consist of?
