Kevin D Pem
RVF 1K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
You were right not throttle position sensor…still at a quandary?Keep looking! I think it's not that sensor! Why? Because throttle sensors typically have a dead spot, and when past that location resume proper operations!
I checked fuel pressure and pump all good Initally I replaced fuel and filter no codes.never got hot.air intake all clear new filter, doesn’t run bad starts everytimeHave you put a Guage on fuel pressure?
Regulator, fuel pump???
I would love to take it to dealer and have them diagnose it, but I live in Bay Area they don’t let and motorhomes in for repairsI bought a truck that had your problem. I bet on the throttle position sensor as well. Turned out to be the MAF sensor! What confuses me is no codes.
Not a skipped chain if as MAF orO-2 sensor it would codeA MAF can be a problem. Same as an air leak. Skipped timing chain would give a crank position error. Ignition would give a miss code. O2 sensor should give code with leaks and MAF, but those two are where I'm leaning. MAF is not that expensive, I would replace and do another test drive. Quality of gas may be an issue as well.
Everything should code! Well except bad gas.Not a skipped chain if as MAF orO-2 sensor it would code
I agree..no codes ever.. never got hot..always well maintained 20,000 miles on it.. soon as it happened I 5hought I got bad gas…replaced,all the gas…fuel filter and checked pressure all was good…Everything should code! Well except bad gas.
