BGMAC
RVF Expert
- Jan 28, 2020
- Cypress Inn, TN
- Forest River
- Georgetown XL M-369DS
- 37ft
- F550
- Titan V10
- 2020 Polaris Slingshot
I've had issues with balancing. It can be either the tire or rim out of balance. Many issues are due to tires “out of round”. There are some places that will “true” a tire while on the rim. This is a process of cutting the high spots off of a tire that is out of round then balanced. Believe me it works very well. There are 2 ways to do this. 1) is while the tire is mounted on the vehicle. If you choose this option you may find that you may not be able to rotate tires because this trues not only the tires imperfections, but wheel, “and hub”. 2) off the vehicle. This trues the wheel and tire and rotating the tires on the vehicle would not be a problem.
if you are installing brand new tires, make sure the installer checks for roundness after install on the rim. Spinning the tire on the tire balancer to see it there is any up and down movement. If there is, make them replace the tire before they are installed on your vehicle.
