My older model Dutchman converter is not charging the battery like it should be. The voltage at the converter and the battery are the same. Around 7.8 volts. There is only about 1.3 amps at the battery. The voltage at the 12 volt coil is relatively the same as the rest of the voltages mentioned into earlier.
Thought?
Thought?
