Hello Folks,
We took our new 5th wheel out on its first trip in NC and noticed that within the park there were some areas where my truck rear bed rails came within an inch of contacting the 5th wheel (behind the pin). At one point it did make contact, but we were going very slow and were able to back out and line up the truck and 5th wheel to get past the problem area without causing damage.
Specs are as follows:
Truck:
I was camping with friends who had a 5th wheel as well, but they didn't seem to have the same issues (different truck, hitch and 5th wheel). The park was rough in some areas, but again, none of the other 5th wheels had this problem.
My questions are:
1. Is this a common issue that 5th wheel owners look out for?
2. What is an acceptable bed rail clearance at level?
3. Would a longer/taller pin box solve the problem?
4. What other factors am I missing.
Thanks for all the information in these forums, helpful over the past 2 years.
-Matt
Truck:
- 2020 F350 Single Rear Wheel, 6.75' bed with factory installed puck system
- hitch is a #2714 PullRite OE Puck Series 16K SuperGlide
- 2024 Jayco Eagle 29.5 BHDS
- Pin box is Rhino box and it is already locked into the lowest mounting holes (pushing the 5th wheel highest when connected)
My questions are:
-Matt
