Bushing replacement
hutch
Hello all, this is not mine but looks very similar. Need help narrowing down my search for a new bushing. I've searched pitman arm bushing with not much luck. What's a better title to search for this. Or maybe someone has a link? Thanks!
There is no bushing. The Arm has a tapered pin. You will have to buy a new idler arm and it will come with new pin. If it is attached to the steering box you will need a pitman arm. Even though the grease cup is torn if it is tight is will not cause a problem. The bushing in the arm is not serviceable.
