- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
End of last year I was concerned about having to add oil from time to time and asked others if they were doing so, is this normal for a diesel engine. Answer was no. I took it in to have it checked and they replaced the oil pan gasket. I stopped having to add oil.
A few stops ago on a concrete pad I noticed a small oil area with wet oil. Each stop I'm leaving a small amount of oil. Today I took it to Cummins and they put die in and did a compression test and found the oil leak coming from the top. A head gasket is required. It's a week long service, 30-40 hours labor, rate here is $138/hr, add parts. Not cheap. Thankfully it's under warranty. As it's not critical it will be done after the winter trip.
So the word to the wise, as we do while our "house" is under warranty, while your engine is under warranty be looking at it under a magnifying glass for issues like this. I'm lucky I noticed it on the concrete pad.
