mansracing
- Feb 23, 2023
- Rogers,MN
- Essex 4531
- Spartan
- X15
- Stacker Trailer
Yes the DSS would send a “all sensors normal” message to the ECM, but it wouldn’t be a good idea in this case because his DEF head is probably working, indicating he has an DEF actual problem. The DSS is better suited to dealing with false readings, such as low DEF when you know the tank is full. Bypassing the DEF header when there is an actual problem doesn’t fix anything and might make things worse.So in team bradfield’s situation would the DSS device work if he were to go into derate mode?My 2018 Essex is now showing a 4331-16 HIGH code.Spartan is saying it’s a problem with the Dossing unit.Incorrect quantity. Is this something that could put me in derate?
There are a lot of cheap J1939 code readers that work, and many will clear codes after the problem has been corrected, but after trying several, including OTR which is great but requires an annual subscription, I’ve landed on this one as ideal for the coach owner:Rich W you suggested buying a code reader do you have any suggestions on which one?Can they also reset codes?Just trying to learn more about the Def system.
Yes. In the event of a DEF head failure, when all else is working fine, the DSS sends a simulated “all is well” message for the three sensors (level, qual, temp) to the ECM. It will only work on a 2016 or later chassis.Is the only time you would use the DSS device if there is a problem with the def head?Deff sensor or fluid level?
Thanks for all your help and info.
Randy
This is a great deal - half price, and they don’t always have used units available. I bought mine used and couldn't tell it from new. Also their customer service/tech support is outstanding. But you can also retrieve codes from your dash, and there are numerous cheaper J1939 code readers on Amazon.Used Diesel Laptops Handheld Heavy-Duty Scan Tool with Regen
Please Note: This kit is used and is in good condition. The Diesel Handheld scanner is very simple to use. This handheld is specifically designed for the heavy-duty market. It allows reading and clearing of DTC’s, Live data reading, and even DPF regens on most makes and models. This tool comes...www.diesellaptops.com
Yep, exactly, now I'm afraid it will pop up again traveling through the mountains this springWell that is good. If you are like me, you probably hate it when things just “clear up” and you don’t know why
