Kevin D Pem
RVF 1K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
Guess I need to reread this post! I thought he was looking for alternatives for what he had. 24volts is an excellent alternative.As I said, a unicorn. These kind of questions are better asked in forums that deal in exotic conversions, like the one I got into to study this a bit. There are people out there that have done some nifty things, but they are like you and live on the edge of what can be done. Not your typical camper people.
I was interested to read the negative views from well informed people on the conversion being done that was very similar to what Degnr8 wants to do. It is doable, it can work, but it requires adjustments to how you live in it and requires constant attention and care. In particular, that guy insisted he was going to us a DC air conditioner and he was told repeatedly it would not work. It simply could not produce enough cooling, even in a small van. We all learn from doing things and finding out for ourselves. Have fun experimenting!
What I do has little to do with living on a edge! I just don't accept status quo as the best alternative. It might be but then!!!
Commercial diesel trucks frequently use 24volt systems. Friend has a Ford one ton it has 2 batteries so it has the cranking amps needed for the diesel in it! Only answer I have for it being 12v is most work will be preformed by auto mechanics. Anyone that was around 6v autos saw the advantages of 12v when the shift occurred.
The reason the Poster should stick with 24volts is because that is the way the rig was set-up. If most of the system was trash, the choice would be open!
For the record I have the 12v system intact, because that makes sense! After he has the solar up and running on 24v he will know the advantages.
