RKins
RVF Expert
- Nov 15, 2019
- Sarasota, FL
- London Aire
- 40'
- Spartan
- 6CTA 8.3L Cummins.
- 2008 Jeep GC Overland
A converter takes 120V and converts it to 12V - could have charger built in. An inverter is connected to the battery bank and takes 12V from battery bank and supplies 120V out - could have charger built in.
You said that everything works when the engine is running - that indicates to me that there is an inverter in the mix. Most inverters will not run the AC or other high draw appliances though. There usually is two electrical banks in an RV when it comes to the Inverter output - circuits it will power, like certain outlets, and circuits it won't power - real heavy draw circuits, like electric cook top, AC, water heater, etc. The inverter will only invert as long as there is charged batteries. The engine is probably providing a charge to the batteries. The real test is like when you're boon-docking - no power pole to plug into, no generator all the time, only charged batteries. In this situation can you turn low current AC things on? That shows how an inverter works.
