AbdRahim
- Dec 25, 2019
- BayStar 3626
- 37’
- Ford
- V10
- None
I got what should be a upgrade on Amazon. I think these guys read Neal’sshutoff valve postThat cartridge is available. I have replaced a couple of them for people. Just get the numbers off it and see if local big box stores have one or Amazon. I ordered one and then found them in an HD.
I did see the direct replacement on Amazon and e-trailer.
Now with the outlet on the bottom, I am not sure if the wand tube will reach. I will look to see if I can find an extension. It could be installed upside down. That would reverse the hot and cold.
The other issue is, I may have to put a couple of pieces of wood behind the screw holds as a. A king to help support the weight.
I learn from all of your comment, so thanks, and keep them coming.
