Buly
- Nov 3, 2019
- TGO Titusville FL
- Dutchstar 4369
- 2014 Honda CRV
I agree...Blue Loctite for me, and no problems. Loctite holds my jeep together, so should work for my newmar too.So far, we have found that a good application of LocTite Blue (which Newmar did not do when they put our coach together) has resolved the problem of slide-motor bolts working loose. We do check them periodically, however.
Thanks for the explanation. Now I am more convinced that my loctite & paint line are more than sufficient.Looks like one end of the bar has a hex hole and the other an 18-point (?) hole. The provided bolts have a grove for C-clips. When in place, the screw heads are prevented from turning by the socket-type engagements at each end of the locking bar and the C-clips keep the bar from popping off. Looks like it should work fine, but I can buy an awful lot of LocTite Bluse for $75.
