B52Bombardier1
RVF VIP
- Nov 28, 2021
- Louisiana
- Explorer
- Scout
- 18 feet
- 2017 Chevy Silverado 4x4
Hello,
I'm on my second poorly designed, two-wire Dometic thermostat. It's on-off switch is poorly designed because the primary switch contact is a metal bar that requires a precise clearance and metallic stiffness to allow contact with the other bar in the circuit. I've bent this small bar a few times to get the thermostat to mechanically and electrically work again but the the metal in the movable bar has a "memory" and it returns to its original, very slightly different shape and the thermostat fails at that point.
So . . . I'm not buying another Dometic thermostat of this type. Does anybody have any suggestions for a similar two-wire thermostat that is more dependable and might even have a temperature gauge built into the face? I'd even go for something battery powered here that is more dependable and modern than what I've been using.
Many thanks,
Rick
Many thanks,
Rick
