The diverter manifold behind the panel cracked during the last freezeWhat is wrong with the one you have, i.e. can you or a mobile tech fix it?
That would be worth looking into. I will ask my tech if that is an option. The manifold is molded plastic and may be worth a shot if no replacement can be foundPicture? Can it be repaired by a plumber or some expert? Weld or some other method?
May be my only option if I can't locate the part.. Appreciate the info
