easterdr48
- Jan 16, 2021
I seen this product online. Thanks for replying to me.Don't think you can do any better than Henry's tropi-coat 100% silicone roof coat. The product according to their website is formulated with RV rubber roofs in mind. You won't be unhappy with the warranty either.
I will attest to the quality! Have used it on 3 roofs, and painted a plywood slide in camper that went through a tornado and was totally dry when I was able to inspect it. They use humidity as it's catalyst, so won't effect your roof.I seen this product online. Thanks for replying to me.
ThanksI will attest to the quality! Have used it on 3 roofs, and painted a plywood slide in camper that went through a tornado and was totally dry when I was able to inspect it. They use humidity as it's catalyst, so won't effect your roof.
I thinking about doing the roof in June in southeastern VA. Humidity shouldn't be an problem. Thanks for reply. How often need to repeat process on rv roof?Thanks
Thanks so much.It’s been on for 2 1/2 years now. No issues. Just keep it cleaned.
Henry 100% silicone will likely outlast your RV.I thinking about doing the roof in June in southeastern VA. Humidity shouldn't be an problem. Thanks for reply. How often need to repeat process on rv roof?
