Kevin D Pem
RVF 1K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
In an accident, totaled is the best result.
So vacuumed construction is the issue! Simply put, the manufacturer relies on the foam, and it's glue bond with thin underlayment to maintain integrity! That with just enough studs to shore stressed weak points.
Because you can't replace their stud with your replacement stud, due to the foam construction, your wall is subject to flexing inward or outward due to lost integrity. No matter how strong the window assembly, that stud you cut will no longer keep the wall from bowing. That will in turn weaken the glue bonds in both the foam to plywood bond, and the bond between the plywood plying. When they give way find a wrecking yard!!! Why? Because every attempt to fix it has a self induced failure point!!!
Only exception is to shore up with frame, ceiling to floor cabinets, or some other similar addition!
