Question Slide out
gscrsigs
I have a 2022 dutchman aspen 29db with a slide for dinette/sofa area. Camper level at a seasonal site and after running the A/C I had a leak in the center of the slide roof? Looked on slide roof and saw A/C condensate was dripping off main roof onto center area. Once that water hit slide roof it did not flow to the outside of the slide it stayed near the campers roof. I had to bring slide in a ways to get the seal past what appears to be a low spot near the campers roof about in the center of the slideside closest to camper when fully extended. Also, the slide when out, there is a ridge that runs under the carpet about a foot under carpet. Should that be flat under carpet or Is the slide not going out far enough? I am fearfully if it rains when out I will be in big trouble. What would cause that little dip in slide roof? Camper was bought new just a couple months ago. Any help appreciated. Thanks
You have reason to worry!!! Make them fix it, it will not go away.
