- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
You highlighted the common mistake...and I made it in my post.Difference between DPF and DEF please? Also when you say sensor do you mean the NOX sensor? Just had that replaced and still get "Low DEF" readings and check engine light on. Just came from Nappanee and they did a regen as part of the annual checkup.I don't ever get anything that say regb in progress on the dash. Thoughts?
Dpf---diesel particulate filter
Def --disel exhaust fluid.
The sensor that is failing is the def head sensor. This is responsible for sending levels, temperature, and concentration levels to the cummins computer
When this sensor fails, the emissions system is still 100% operational, but the cummins code is disabling your ability to drive because the sensor is not sending good data every 1 second.
The emulator resolves this problem. It sends good data every 1s. It does not send real data, just good data. For this reason your levels need to be manually checked.
If you run out of def, other parts of the system will shutdown and disable your ability to drive. The emulator is not a defeat.
