Tire Monitoring System
I had to buy a new set last year and bought TST… have been happy with them. The only two that are flow through are the inside duallys since Freightliner took my valve extenders off. :-/
So if you have the OLD EEZ system like I did and you UPDATE it by buying the new color monitor, the old repeater (booster) will not work with the new monitor. Sure enough, I looked at my repeater and it had a red light hence all the beeping for losing connection.
Phil in tech support at EEZ was very helpful and again I highly recommend EEZ. They also will send the E618 booster to use free of charge for 30 days with their trial booster program. If it's a go, it costs $55 plus shipping.
Good stuff. Finally got around to I stalling the new E618 EEZTire. It went very well. I ordered the booster at the same time...and swapped it out with my old TST booster. I had put the project off for a while because I wanted to 3d print a RAM Mount Ball adapter for thr display head. Glad you found the beep culprit. Those noises can drive one crazy.
