Question We need help with a 2004 Fleetwood Discovery 39L
Bsutton
The monitor panel for the tank levels and the propane tank level is up at the front of the coach, up over the passenger side dash. It seems to be divided into two parts, and the upper part related to the tank levels suddenly quit working about a month ago. We have been trying to research a fix for it and so far have replaced the circuit board, and it didn't fix it. So, upon checking more of the wiring behind all of it, it appears there's no power coming to that circuit board. Can anyone tell us where the specific fuses for this board might be hiding? We have checked a bazillion fuses in various places, and so far have not found the one to that board (at least as far as we know). Thanks for any help or suggestions. Jeff and Becky Sutton
I have a 2007 Expedition 38L which is pretty much the same coach. There's a fuse block under the center of the dash but it's more likely in the main fuse block in the house battery compartment. You should be able to get a build sheet and diagrams from the REV website with your VIN and coach number
