- Dec 25, 2022
- Monterey Bay and Palm Desert
- Dynaquest
- XL 3801
- 40’
- M2-112
- Cummins L9 - 450Hp 1250 Tq
- Mojave - JT
Well fortunately you can easily access your motor to check such things.OMG WWJD, five dollar mistake. because of you I’m now double checking my ISL 9 to make sure everything is tight and secure. I am so sorry you had to revisit this whole situation. Absolutely terrible what you went through. Thank you for all that you did and shared.
No I bought it in 2020 with 16k on it. It was pristine then - not so much now (65k and counting). But…WOW, what a difference 8lbs of boost makes. I had the most wonderful day crossing Nebraska and Iowa ever (with boost as high as 32psi). All because this thing now runs as it should. Good enough for me. I’m simply elated that Truck Center Companies was able to finish the job that Floyds started and correct Floyds’ errors.@Rich W. are you the original owner?
My guess is that the extra inlet pressure may benefit the compressor system, maybe allows for a smaller compressor or less run time, but it would have no benefit at idle, low throttle conditions, or deceleration, so……? Whatever but I agree, the fewer complications to the intake system, the entire system actually, the better.I'm also curious as to why the move from drawing compressor air from the air filter to downstream of the turbo? I have my guesses but it seems to me (and has been confirmed by this whole debacle) you end up making a less reliable power plant by doing so.
I did a little more research after reading your post earlier this morning and this is not an uncommon problem - apparently chafing from clamps or zip ties, and rubbing on supports, as well as weakness in a 90° turn on the hose, can all cause this. And because it causes a relatively small leak (1” hose vs 4” inlet and outlet pipes) it just reduces boost enough to rob power, unlike a turbo boot that will about shut you down. There’s even a TSB on it for Navistar. Just another over-engineered complication we didn’t need.I'm also curious as to why the move from drawing compressor air from the air filter to downstream of the turbo? I have my guesses but it seems to me (and has been confirmed by this whole debacle) you end up making a less reliable power plant by doing so.
I guess it could be as simple as less and smaller diameter hose because the source is both under positive pressure, and closer to the compressor so cheaper. Personally I think its kind of dumb to have any more possible intake leak sources than absolutely necessary. I guess they don’t have high school auto shop anymore.I'm also curious as to why the move from drawing compressor air from the air filter to downstream of the turbo? I have my guesses but it seems to me (and has been confirmed by this whole debacle) you end up making a less reliable power plant by doing so.
