What could be my problem
No wiring schematic.that my problem I'm guessing
Well the solenoid jumping is a very good clue. Does it start when you do that or just turn over? If it starts when jumping it then you have power to everything accept the ”S” terminal when the key is on, and that would be the one to trace back. This is all still in the “guess” category of course and you may already know this, but it’s all I got right now.
The problem here is parts swapping prior to diagnosis. It seems clear there is an electrical problem somewhere, and there are quite a few possibilities as the above posts pointed out, and the old starter and ignition switch were probably still good. Replacing components of a system until you find the problem is not the preferred method of diagnosis.
Where can a person get a wiring diagram or schmatic
