What happened in Vegas, isn't staying in Vegas!
CaptainGizmo
RVF Expert
SoCal...relax, we're one of the good ones! ;-)
Newell
2020P
2017 Ford F-150 Raptor w/AF1 Braking
Had to get our baby all gussied up for the NEWELL RALLY.
Soooooo....
Yup, had our Newell Ceramic Coated at Bob Moses in Las Vegas!
These guys do INSANE work and are more than reasonable, when comparing anything else you can throw at protecting your coach.
They took a week to perform mild correction, masking everything, then coating with SENSHA Ceramic Coating. This coating, and their services are warranteed for 5 years, but they are fully confident it will last well over 8 years; given the quality of a Newell's paint job.
NOW she's ready for the lights! ;-)
Soooooo....
Curious, What are the maintenance requirements afterward?? Just wash & keep clean? Or a type cleaner/polish needed? Thanks for the information!!
Your coach looks AWESOME!!
Wowzers!
Great question…And thank you!
The best thing about ceramic is, most of the time, all you’ll need to do is give it a quick spray from a foam cannon with a pH neutral shampoo, then rinse with DI water! On occasion, you can use a lambs wool mitt to get heavier dirt and/bugs off.
Upon departure, they’ll give you all the instructions you need, along with complimentary SENSHA detail spray and soap to get you started. For most vehicles, they want you to come in annually so they can inspect the coating to make sure there are no areas that need touch up. This is super important with gel-coat/fiberglass applications. But, again, they’ve got so much confidence with Newells, that it’s really not going to be needed.
I actually made a video to detail the process. I can’t say enough about Matt Moore and his family. The founder is Matt Moses in Arizona and has been building an incredible company with over 10 franchised locations.
Here’s the video, if you’re interested:
