Hello. I’m still getting to know our 08 holiday rambler admiral.
How do I remo the radio rocker switch to check?
My radio isn’t working although all relative fuses are good.
Please advise
Rod
Please advise
Rod
Rocker switches generally have squeezable tabs behind the switch. I'm not familiar with your coach but I suspect it is held in place the same way. In order to access the back of the switch there must be a panel or perhaps the dash pad that needs to be removed for access. Since you have to access the back of the switch, you may not have to remove it. You can test the switch to discover if there is power to the switch just by accessing the terminal.
I have added a You Tube link on the removal of rocker switches. If you can, add a couple of pictures of the switch and the dash. Perhaps some of the other users may be familiar with your coach or one like it.
