Towed vehicle turn signal not blinking when connected to MH in Tow Mode
Scobysisters
2015 Newmar Ventana - been towing an F150 for 2 years now without issues, until now. When truck is in Tow Mode and connected to MH, the right (passenger) rear light does not blink. This is the ONLY situation in which this happens. After several calls to various techs and some trouble-shooting, we are STUMPED! We've already ruled out the Tow Flasher Relay and the Tow RH Fuse in the MH, and the "umbilical cord" (7-pin to 6-pin). We've ruled out any issues with the Truck, because all lights/flashers work fine when in Tow Mode NOT connected to MH, and also works fine NOT in Tow Mode.
The Break Lights, Left Turn Signal and Hazzard lights all work fine when truck is in Tow Mode and connected to MH. It's JUST the right rear blinker of the Truck (towed vehicle) that Does NOT Blink when in Tow Mode and connected to MH - it just lights up and STAYS SOLID.
ANY IDEAS before we pay a ton of $$ to Freightliner??
Look at the connection at the light that is not working. There is something that connects the towed lights to the MH. Possibly a diode kit was installed.
I doubt it's a Freightliner issue. I had a similar problem happen to out 2018 JK. Turned out to be a broken wire on the Tow Wiring Harness. It's odd that everything works fine except in tow mode though. It still sounds to me like you have a trailer wiring harness issue. Check that first and cross your fingers.
Darrell
Sounds like dirty connctions. Did you clean the 7/6 pin connections and pin sockets on the cable?
Clean your connector(s), by blowing out with compressed air. Try some electrical contact cleaner. I use JB 80. https://www.lubesuppliers.com/products/jb-80-spray-lube-13-oz]Justice Brothers 80[/url].
If you have two flashers, switch the flashers?
Possible ground back feeding when in tow mode. Does it make a difference when in tow mode and connector is hooked up, but the hitch is not connected?
We had just cleaned the connectors and this didn’t help. What do you mean by “connector is hooked up, but the hitch is not connected?” Which “connector” are you referring to? The blinker works when toad is in Tow mode and NOT connected to MH.
By “flasher” do you mean the light bulbs on the toad that flash? Forgive me for my ignorance, but understanding electrical/auto is challenging to me. :unsure:
Darrell
Where is the Tow Wiring Harness? Is this behind the 6-pin connector on the toad? Or at the MH end? Is this something we can get to? Or is this something an electrician/tech should do? And if so, an RV tech or a trailer tech, or a Blue Ox tech? Who would know more about this issue? We’ve asked RV techs and they said it may be the Tow Relay on the MH - it’s not because we replaced that relay. It’s also not the fuse. Thanks for your reply.
There is no ignorance here
Everyone cannot understand everything.
If the problem only happens when in tow mode attached to the coach, then the coach flasher(s) may be the problem.
If the right light is not flashing when disconnected from the coach but in tow mode, the problem may be in the towed vehicle’s flasher or even the tow mode components.
You certainly have a puzzle.
IMHO, Best is to find the OEM schematic of the circuit in question and trace it back from the bulb with a test light. FMCO has all these circuits nicely diagramed in Service Manuals.
another way to isolate the issue is to apply 12v to the appropriate circuit at the front bumper to see if the problem is truck
Handy tool to test trailer plugs
On My Jeep, I have a "non factory" wiring harness that connects to the Trailer Wiring Socket on the Coach. That harness runs underneath the Jeep to the FACTORY plug at the Left Tail Lamp. It does not use any diodes. All it powers is the Park Lamp circuit and the Left and Right Turn Signal circuits. The Brake and Four Ways use the same circuits. It is a very simple set up and does not use any OEM power from the Jeep.
It sounds like your set up uses some factory circuitry on your F150. If that's the case, I suspect you have a sophisticated Ford problem. Is it too late to buy a Jeep? Just kidding!! :)
Good luck and let us know how your problem was resolved.
Darrell
The wiring system is plugged in. The coach is not physically attached to the tow vehicle. Try in tow mode and not in tow mode. I suspect there is a ground feeding back thru the hitch. Process of elimination.
Some use a diode kit on the tail lights on the towed vehicle. It allows two lines in on one circuit or bulb. I think I said that right. If you are using the tail lights on the towed vehicle there may be diodes used.
I don’t use them. I have small LEDs under my tail lights.
"If the problem only happens when in tow mode attached to the coach, then the coach flasher(s) may be the problem." THAT is the ONLY scenario in which that Rt turn signal on the towed vehicle doesn't flash. The MH flashers work fine when attached to the toad vehicle. So how can this be the coach's flasher malfunction?
We're going to remove the tail light assembly of the toad vehicle tomorrow to look at that wiring. I think we have a diode kit installed in there, from reading more about this. So, we'll see what we can see in there.
Darrell
Haha - we USED to have a Jeep Wrangler as the toad (but hated that jeep) and needed more room (the F150 is our "garage", since we're full-timers). I suspect we have a diode system. We're going to remove the toad's tail light assembly tomorrow as see if we can notice anything amiss.
