- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
In the world of RV's we sure get a lot of opinions and I like "fact checking" or learning more and vetting out some of these myths. In my other post about fast idle some points came up about extended idle. In the spirit of DEF head failures a lot of us now probably keep our engines running vs. engine cycles which can be good and bad as we'll likely discuss below. I personally keep my engine running while fueling now where in the past I did not. Campgrounds I typically do shut off and I am the one that raised the topic here and other forums about being respectful of the noise. While some campground offices are well clear of campers, some are close to campsites and being aware and respectful is a good thing, so I will typically shut down at check-in unless AC is required for fido, etc.
So let's chat about extended idle. Is it really bad? Says who? How long have diesel engine owners been doing this? Any ramifications?
So about that soot build up, idle or not, wouldn't the system detect these levels and start a regen even if at idle? The RPM would come up likely to fast idle at best for a regen, but my thought is even when idle, the system will manage itself, which is my opinion and not fact based at all. Curious what others think?
Are we "fear tactic'ing" ourselves to shut down when maybe it's not really something to be concerned about?
