Still leaning leveling
Russellvh
Forest River
Wildcat Fifth-wheel
2019 Ford F-250.
We have the Lippert 3.0 Ground Stabilizers
We like to use some “pads” under the stabilizers. We use the plastic square type. When on un-level ground we lower the front stabilizers with the same number of pads under each one. If one stabilizer contacts the pads first and there is room for 1 or 2 more pads under the other, we fill that space so the stabilizers are both making first contact. Then we engage the “Auto Level”.
Should we be adding the “extra” pads or just letting the Auto Level work out the adjustment itself?
I ask this because in our procedure the control panel shows “Level” but, after opening the slides and stairs the inside still leans down, slightly noticeable, to the lower side of the site.
I have the equalizer system, Bigfoot on previous MH. In my experience autolevel has never been very accurate. Both MH, if I do just auto level, the front tires are off the ground. I have been doing auto level to get the levelers on the ground, them interrupt it and do manual final leveling before front tires are lifted off the ground. Using a manual level, I get it to where it is level most places in the MH.
I agree and do the same as @AbdRahim
Having been thru three RV/s, the Auto level is pretty much worthless IMHO!!
I put the jacks down till they contact the ground, put my phone with a bubble level app on the floor and do what I need to get the RV level. Most times it only takes a little to get it level. For some reason, when the AUTO level works, it only knows one direction for the jacks, DOWN. doesn't take into consideration that you might have to go UP one leg or side to get it level on that particular side. I've seen too many RV's with the tires off the ground. Just doesn't look safe and from what I've read, it is not good to leave you suspension handing like that. But what do I know. I like the tires on the ground. Makes the RV more sturdy also.
Happy Glamping!!
