New to Towing a Vehicle
Dan_Frisbie
Wausau, Florida
Brinkley
G3520
40’ 3”
We usually have the box trailer with motorcycles behind the Class A, but since my wife bought a 2021 Wrangler (manual transmission), I am considering setting it up to flat tow.
Putting it in the box trailer would overload my hitch on the RV, but the trailer can handle the weight.
I am curious about the tow bar setups out there. Some are quite expensive. Do I need the Jeep brakes?
Would it be smarter/cheaper to upgrade the RV hitch for more weight and use my existing box trailer? The box trailer has electric brakes.
Thanks for your help.
You cannot upgrade the hitch to increase your towing capacity. Your brakes, transmission, engine, and frame are all designed for a certain load.
Roadmaster, Blue Ox, and Demco are the major manufacturers of towing systems. Many Jeep owners have changed the bumper to a stronger bumper designed so the towbar attaches directly to it. Do you need a brake for the Jeep? Yes, and that is a big yes. You not only need a brake but also a breakaway brake. Why? Most states make it illegal to tow without a braking system.
The Blue Ox system we have on our Jeep Wrangler is fantastic, but costly. We have Class A diesel pusher, they installed the system with a separate smaller air tank to handle brakes for Jeep. It can be hooked up and unhooked within 15 minutes easily by one person. The system, I think, was called Air Force One? We had a professional install it and cost of everything was around $8,000, but don't think we'll be replacing either unit in a long, long time so it was worth it.
Regardless of cost, you will find flat towing so much more convenient (as long as you don't have to back up with the toad attached). Finding a site long enough to accommodate your Coach trailer and the Jeep will be more difficult too. And as Texas Clodhopper mentioned, it's probably not possible to beef up your hitch.
We use Blue Ox and a Brake Buddy. Love the Blue Ox but not so thrilled with Brake Buddy. I just don't like how it sits against the driver seat base. We are now towing our third Jeep and would never go back to a dolly or trailer.
Darrell
We have the Blue Ox tow bar and the Air Force One setup. I can hook up and check everything in less than 10 minutes. As others mentioned, not cheap. I installed an aluminum bumper with the integrated tow hooks from Rock Hard 4x4 and installed the wiring harness. Had a local shop install the Air Force One as I wasn't comfortable tackling that one.
If you have air brakes on your Class A, this is a good setup. If you don't have air brakes, check into one of the other braking systems.
If you stay with any of the top rated units, you'll be fine. Not something where you want to pinch penny's. Good luck with your decision.
I always wonder what type/class hitch one has, and what makes them think it needs to be beefed up?
So do what you can to answer those questions. Then I may be able to give an informed answer!
This is not necessarily true.
A 3/4 ton gasoline CC pickup can tow more than my MH is rated to tow. The F53 has a beefier chassis and brakes with a similar engine/tranny combo.
My hitch is limited to 5k.
Is my RV? I need to find out...
My hitch has a 5,000 lb limit. My F53 has a 20,500 limit on the RV itself. Looking for the RV tow capacity...
Your GCWR is 26000 pounds. It is time to drive to the nearest Cat scale.
There are only three aftermarket bumpers rated for flat towing Jeep Wranglers, RockHard, LOD and Smittybilt. I have the Smittybilt which I installed myself. Roadmaster makes bumper D-ring adapters which also fit Demco tow bars. Blue Ox D-ring adapters only fit Blue Ox tow bars. You can buy a DIY plug n play wire harness with diodes for lights. All in, my JK was ready to be flat towed for less than $500. For supplemental braking cost/options, you need to determine what you need to be legal in your home jurisdiction only. Once compliant at home, reciprocity takes care of the rest.
So I'm ready for the flack on this!
5000 is based on hitch weight. The hitch can handle 500. An equalizer hitch can change that 5000 number!
What concerns me is the warning about the vehicle capacity!!! Most front engine MHs have extended frames, and the joint has been known to fail. This applies to toweds as well as pull trailers.
In short, a class 3 receiver should be capable enough with an equalizer hitch, to pull the trailer loaded with your Jeep!!!! Just remember my warning about that compromised frame!!!
I am DEFINITELY no expert on this, but I understood supplemental braking requirements had to be met for the specific state you are driving in. Your drivers license requirements fall under the reciprocity agreements but I don't believe that applies to requirements for supplemental braking systems.
I have the rockhard bumper on my 2020 rubicon. It is a great hitch.
One thing that is often overlooked is the need to be within 2 inches of center between the RV tow hitch and the bumper centerpoint.
Gas coaches often have a higher hitch receiver than the diesel coaches. I had to use 12" riser hitch from Gen-Y to get mine within 1.5" of center.
Regarding Supplemental brakes--I can tell you from personal experience that you want them. I had a breakaway this summer where my front bumper separated from the towbar on one side. This was a very scary moment. I was able to get the vehicle stopped using the one remaining connection, but this was a struggle to do while going down hill on a 2 lane highway. The jeep was in the oncoming lane, and required me to move over to shoulder a lot more than I wanted to. Had it broke away at that point, it would have killed someone in oncoming traffic.
I don't care about the laws, rules, or any other reasoning--Supplemental brakes are just common sense and will save a life.
If my vehicle killed someone because I was too cheap to do it right, I don't think I could live with myself.
