Blind spot monitoring not working
Jim
North Carolina
Essex 4543
2016 Jeep Rubicon
On my London Aire, I have what is commonly referred to as "blind spot monitoring with side camera integration" or simply "camera-based turn signal integration." It's a feature designed to enhance safety by automatically switching the display to show the corresponding side of the motorhome when you activate a turn signal.
Mine is stuck and is displaying the drivers side of the rig. I guess it's not the end of the world, but I really want to be able to see my toad behind me, and that's not possible in this case.
Has anyone dealt with this before? I have a feeling that the problem is going to be in the turn signal area more that in the camera display itself. Any ideas?
On mine I'm able to select the display, I often keep it on the passenger side display while driving. Could you have possibly changed the setting inadvertently?
They fixed an issue on ours last time at the mothership.
They originally used a common ground for the camera system. This caused issues for the system overall.
Fix was to move the camera system to a dedicated ground. They were doing the same fix to a Dutch Star while we were there.
Could be the issue as ours would turn on and I couldn’t change the view. Lucked out that it stuck on the rear horizon camera but lost the 360 view.
Yes, mine too. But unfortunately, the fix is not going to be that easy! But thank you!
So when you say the "camera system", do you mean the actual cameras or the display?
May I assume you’ve already tried resetting with the battery disconnect switch?
No I have not done that. Really don't think there's a chance that is the problem, but I'll go ahead and do it anyway. :)
Find the box that the cameras are plugged into. On gassers it is usually under the dash. May require some disassembly. Now Now swap two cameras. If the cameras are functioning, view should change. Try this with each camera to see if the cameras are functioning. If so than the problem is elsewhere (wiring, or the box itself), perhaps.
Reminds me, I need to find that box on mine before I need to. Hopefully I won’t need to.
Just crawled under mine. Of course it is not visible. Have to take off the bottom of the dash. Fun!?
Sounds like a display issue, not the camera or the system.
Was the box where all the cameras connect before going to the display.
Ours is in the overhead above the cab, and appeared to be the same location in the Dutch Star I saw at the mothership.
The ground they connected to was used for other items and moving it to a dedicated ground solved the issues we were having (rebooting on its own, unable to change camera view, static coming through the speakers, etc)
My rig is a bit older than yours, but I'll check and see what I can find. For some reason, I figured the problem would be somewhere around where the actual turn signal arm goes into the column. But maybe not. I'll see if I can find to box you are talking about.
May be able to call and ask where it is located. I know the Dutch star was above the cockpit area also. Shouldn’t be too far from the head unit since the cameras go there after the box.
