Tire Shine
#1footballfan
Colleyville, TX
Dutch Star 4369
43 ft
Cummins
2024 Jeep Rubicon
Does anyone have a product they really like that gives your tires a great shine. I’ve used the 303 spray in the past. However, when ordering it thru Amazon, there are times when I receive it the spray can does not work. I’m looking for the best solution.
EW.....no no no on the 303!!! Leaves residue, attracts dirt, and doesn't last.
I've become a big fan of ceramic tire dressing! It provides incredible shine (if you want), goes on super easily, dries to a NON greasy finish, and it LASTS A LONG TIME!
I hated the stuff from Armor-all because the stupid nozzle clogs and wasted the majority of the can; they never sent a replacement either.
So, back to my favorite detailing company...ADAM'S POLISHES!
This stuff is GREAT and comes in their standard bottles and never a problem.
I guarantee you'll be happy with it!!!
It's also IMPERATIVE that you use tire cleaner to get all the residue and release agents off. Many people never do this and are missing out on how good tires will look. It's also better for the rubber, getting all the junk off. Again...Adam's for the win!
I agree with @CaptainGizmo that 303 is not the right product.
I personally use the entire collection from shinesupply.com
Thank you. What are the names of the products you actually use. Also, do you use anything specific or special for the rims ?
I 2nd Adam's Polishes. We have been using their products for many years. These are the 2 products that I use on our tires.
Rubber and Tire Cleaner
SVRT (leaves a matte finish, not a high gloss)
An AI perspective, GROK2, on Tire Dressing (personally I’m in the soap and water camp)
When it comes to RV tire dressing, there are various perspectives and recommendations to consider:
**Against Tire Dressing:**
- Some RV enthusiasts and tire experts, including those from Michelin and Goodyear, caution against using tire dressings. They argue that these products can potentially degrade the tire material, particularly if they contain petroleum distillates or other harsh chemicals. There's a consensus that tire dressings can attract dust and dirt, accelerating wear or causing premature aging. For instance, Michelin recommends cleaning tires with mild soap and water only, and advises against any form of dressing or covering.
- There's also mention of no direct comparison test data supporting the UV protection claims of many tire dressings. Roger Marble from RVtireSafety.net points out the lack of empirical evidence for these products' effectiveness in preventing UV damage, questioning the benefits versus the potential risks.
**In Favor of Tire Dressing:**
- Other users and some product reviews advocate for certain tire dressings, particularly those that are water-based and free from harmful solvents like petroleum. Products like 303 Aerospace Protectant or Aero Cosmetics Ceramic Tire Dressing are often cited for providing UV protection while giving tires a matte, non-dirt attracting finish. These products are praised for maintaining the tire's appearance without the negative effects associated with traditional tire shine products.
- Enthusiasts who like their RV to look well-maintained often use these dressings for aesthetic purposes. They argue that if the tires are not kept beyond their service life (typically up to 6 years), the potential degradation from dressing might not be an issue since the tires would be replaced before significant damage occurs.
**Neutral or Practical Approach:**
- Some RV owners adopt a middle ground, using tire dressings sparingly or only for aesthetics during shows or special events, while ensuring regular tire maintenance like proper inflation and inspection for wear and damage.
**Conclusion:**
The decision to use tire dressing on RV tires involves weighing aesthetic preferences against potential tire health concerns. If you opt for dressing, choosing a product known for safety and UV protection, like those mentioned, might mitigate risks. However, it's also wise to follow manufacturer recommendations, which often lean towards minimal or no use of dressings. Regular maintenance, including checking for signs of dry rot or cracking, is crucial regardless of whether you use dressing or not.
For more detailed guidance, you might look into RV forums, manufacturer guidelines, or specific product reviews on the web. Remember, the longevity and safety of your tires are paramount, so any decision should prioritize these aspects.
Not to beat this to death and still not answer the question posted😎
More AI tool fun
Here's what some tire manufacturers recommend or suggest regarding tire dressings:
- **Michelin**: Michelin advises against using tire dressings or protectants. They recommend cleaning tires with mild soap and water. Their stance is that tires are already formulated to resist UV light and ozone, and dressings might remove protective waxes or antioxidants from the tire's surface, potentially leading to premature aging.
- **Goodyear**: Goodyear does not endorse or prohibit the use of tire dressings. They state that the decision to use such products is left to the consumer, but they take no responsibility for any effects these substances might have on the tires.
- **Continental**: Similar to Michelin, Continental does not recommend the use of lubricants or chemicals on tires, advocating for cleaning with soap and water only.
- **Bridgestone**: Bridgestone also indicates that their tires include antioxidants and waxes to protect against environmental damage. They caution that while tire dressings might improve appearance, they could inadvertently remove the protective layer that naturally forms on tires, thus exposing the tire to harmful elements.
**General Recommendations:**
- **Water-Based Over Solvent-Based**: If you choose to use a tire dressing, web forums and tire care discussions often lean towards water-based products, which are considered less likely to harm the rubber compared to solvent-based dressings.
- **Avoid Petroleum-Based Products**: Tire manufacturers and auto detailing experts generally advise against using petroleum or solvent-based dressings due to their potential to degrade rubber over time, leading to cracking or dry rot.
- **UV Protection**: While some dressings claim to offer UV protection, there's skepticism about their effectiveness without independent testing. If UV protection is a concern, look for products that explicitly mention UV inhibitors without compromising the tire's integrity.
- **Manufacturer's Guidance**: It's worth noting that while these are general stances from tire manufacturers, they might not specify particular products. Instead, they provide guidelines on what not to use or caution against using any dressings at all for the sake of tire longevity.
In summary, tire manufacturers generally caution against the use of tire dressings, advocating for regular cleaning with mild soap and water. If you do decide to use a dressing, selecting one that is water-based and free from harmful solvents might be a safer approach, but always consider the tire's exposure to elements and the potential for reduced tire life with any chemical application.
A little tidbit..
did you know one of the ways they recycle old tires is to place them in a vat and hose them with hot oil?
the three byproducts are:
oil
Carbon black
reinforcement belts
nothing else left, that's all there is! If you want to fact check, build a dam using puddy on the side wall of an old tire and fill the dam with motor oil, and give it a few weeks for the results.
I found out the hard way when a can of oil was punctured, and oil went into the trunk spare tire well.
Use the 2 links to show you the exact products!
Adam’s Graphene Tire Dressing
Adam’s Tire and Rubber Cleaner
BTW, I’ve used their VRT dressing, religiously, on dozens of vehicles over the last 5 years. And, while it is awesome stuff, it’s no match for the dryness and longevity of the ceramic/graphene dressings.
Thank you for this information.
I use Armor All and it leaves my tires looking really good. Haven't had an issue with the nozzle plugging to date.
I love McKee's 37 Gloss Tire Gel! It's non-petroleum, contains UV protection, doesn't attract dirt, it lasts for quite a while and doesn't sling off. Just bought another gallon earlier this month. I use a paint brush to apply it and use dawn soap with water to clean it. Typically apply it 2-3 times/yr for the past 4 plus years. Prior to applying, you need to clean the tires and typically needs two coats. I full time, never cover my tires and the side walls really look great. You'll also find they sell quite a lot of detailing products.
I also like nice looking tires but do it differently.
I clean my tires with "Super Clean". The stuff in the purple jug.
Get the tire wet, dip a stiff brush in a pan of Super Clean and scrub. You can see the dirt and grime come out of the pores of the tires. The soap turns brown. It usually takes 2-3 rinse & scrubs to get that new look.
Richard
I appreciate all of the input for the tires.
Another question for all: what and how do you clean your rims. I am just using soap and a brush to clean them only. Noticed a few things need a little my elbow grease but wanted to see what you guys use.
Like you, just soap and water with a microfiber cloth then wipe dry with a microfiber. Sometimes use Wash Was All with a microfiber cloth.
Just for clarification...when I said "the stuff from Armor All", I was referring specifically to their Ceramic coating...terrible dispenser problem, but the product itself was ok when I ripped the can open and applied it with a sponge...PITA.
Old school Armor-All, IMHO, has been long surpassed by other offerings like 303. But it sure brings memories of the 70's back! ;-)
OK...I trust you...a two pack it is! I apply the dressing for looks only. IMHO the price is right on this stuff so if it works that's even better. Blessings
My Rubber Cleaner and Tire Dressing both arrived today. So much for Amazon Prime 2-day delivery.
