Richpatty
- Nov 2, 2019
- Wesley Chapel, NC
- Ventana 4310
- Freightliner
- 400hp
- 2007 CR-V
Is this directed to me? I would simply peel the screen away from the bottom just enough to open the window and then put something to hold it open (pen, pencil, etc...) and then reattach the screen.True… but how do you prop it open?
Interesting….but it appears to be a replacement part and not for windows that are not designed this way originally…. Although I am sure some custom work could be done to make it work.You can solve the propping of the window with this add on arm for just such.
Amazon RV Exit window latch
Rich, this is what I added to our window and Bonnie made a screen with velcro edging that secures around the window frame. Seems to work fine. Sorry, can't get a pic now but I'll send one to you if you like when I can get back in the coach.You can solve the propping of the window with this add on arm for just such.
Thanks Jim,Rich, this is what I added to our window and Bonnie made a screen with velcro edging that secures around the window frame. Seems to work fine. Sorry, can't get a pic now but I'll send one to you if you like when I can get back in the coach.
That looks like it would really help air flow in bedroom! I might try that.. Thanks for postingNo hole, I just cut a small notch in the lower frame and it holds fine. I still use the original window locks. Hope the pics help.View attachment 27037View attachment 27038
