Question Is extended idle really bad for a Cummins diesel? Fact or myth?
What exactly is "excessive" or "extended" idling time. Is it 5 minutes or 15 minutes or 30 minutes?
Even owners manual don't give a figure. :unsure:
Ok, so why do trucks idle all night, and some diesel train engines are almost never turned off in cold weather?
From ChatGPT, for what its's worth.
Idling your Cummins 605 HP diesel engine for 30 minutes won't cause immediate damage, but it's not ideal for long-term engine health. Here’s why:
Potential Issues with Long Idle Times​
  1. Carbon Build-Up – Diesels need heat to burn fuel efficiently. Extended idling can lead to carbon and soot buildup in the EGR system, DPF (if equipped), and turbo.
  2. Fuel Dilution – Unburned fuel can mix with the oil over time, reducing lubrication and shortening oil life.
  3. Glazing of Cylinder Walls – Low cylinder pressure and temperature during idle can cause improper ring sealing, leading to potential wear over time.
  4. Wasted Fuel & Cost – A big Cummins like yours probably burns 0.8–1.5 gallons per hour at idle, which adds up.
  5. Cooling System Inefficiency – The engine isn’t working hard enough to keep coolant and oil at optimal temperatures, which could affect performance down the road.
When is Idling Okay?​
  • Cold Start Warm-Up – A few minutes of idling (5-10 max) before driving is fine, especially in cold weather.
  • Cool-Down After Hard Driving – If you've been pulling a heavy load, a 5-minute idle helps the turbo cool down and prevents coking of the oil inside it.
  • If Required for Specific Accessories – If you're using an air compressor or generator that depends on engine RPM, idling might be necessary.
Best Practices Instead of Long Idling​
  • If you're parked for a while, use a high-idle feature (if available) to raise RPM to ~1000+ to improve combustion.
  • If possible, drive instead of idle, as diesels prefer load over extended low-RPM operation.
  • Consider an auxiliary power unit (APU) or generator instead of idling for long periods.
Bottom Line​
A one-time 30-minute idle won’t kill your engine, but making a habit of it isn’t great for longevity. If you must idle, bump the RPMs up slightly to reduce carbon buildup and improve efficiency.
Many of those trucks are pre any kind of emissions controls.
