Question Newmar maintenance
Rich-MLsRV
Colorado
Dutch Star
2020 Jeep Cherokee
Folks,
The factory appointment rep sent me the maintenance sheets for me to decide what to have done. At the bottom of the chassis maintenance sheet is the following. What is criteria for doing an alignment - mileage, time, etc? The sheet does not specify when this is to be done. I am also asking the factory rep but wanted others to provide their input. I'll be in Nappanee in September for the 12K chassis service and some warranty items.
Rich
2024 DS 4081
Unless your seeing signs of uneven tire wear, pulls to one side or another, didn’t run of the road or extremely rough roads all should be good. If your in doubt ask yourself if the cost is worth your peace of mind 😀
Quote is reasonable based on cost of alignment I had done at Spartan.
Folks,
Rich
2024 DS 4081
Just curious, Rich, but how long ago did you schedule your maintenance? I have until August 23 before my extended warranty ends, and I really need to get an appointment scheduled.
Here’s what the factory rep said in the email response
“Please let me know on the appt. date for sure, we do not mind starting the appt. on a Wednesday, but prefer to start on a Monday if possible. We currently have any date available from 6/16/25 on.”
I would book as soon as possible to get your preferred dates.
I would bet some ware in your paperwork/owners manual there is a small notice that basically says. When loaded for travel you should get a "all wheel" alinement done.
Bill
Folks,
Rich
2024 DS 4081
Unless something happens to cause concern (hard curb hit or big pot hole at speed) or you see uneven wear, or you had steering/front suspension components replaced, I would wait until you get new tires, and even then if the old ones had even wear I wouldn’t touch it. On a 2024 it should be a long way off. The maintenance menu doesn’t specify because it’s “as needed”.
I would not let anyone touch my alignment if my tires showed no uneven wear.
I personally would not take it to Newmar for alignment. I'd be going to Freightliner. Newmar gets these frames in already assembled. Not sure of their expertise. Motor and frame work, I go to the manufacturer for maintenance.
We just scheduled some things I’d rather have them do. Our appt was set for Aug 11.
I called yesterday and was told end of June or first part of July. Got an email short time later to agree to their pricing. The fellow I talked with said that I wouldn't have a definite date until they called me back, and that could be 2-3 weeks. o_O
@Jim, another option may be to go to the International rally in in WV in early June. All of their techs will be there.
Yeah, they told me the same about a couple weeks for getting back to me. Was just a couple days though.
I did ask for August though.
