In Over My Head Electrically
Ifr4phun
My knowledge on batteries/solar/inverters is VERY limited. My 4 AGM batteries in my 07 AE 42F bit the dust. Since it's getting warmer out, I ordered 4 100 amp Lithium batteries. My plan was to just replace the AGMs. The more I read I'm now wondering if I need to replace my charge controller, re-calibrate my invertor and will my converter charge my batteries when I'm plugged in to shore power? An advice in LAYMEN's terms would be appreciated.
Thanks in advance
Bryan
Thanks in advance
Bryan
Robert @FullBoar in Albany, Oregon can explain it all to u. he helped me with my newmar.
It is often more complex than just the batteries. You have to look at you instruction book to see if your inverter/charger has a Li setting. You may also have to change your BIM. Best to consult a professional, to protect the rest of your system.
Where are you located. Perhaps someone can recommend a competent professional, near you.
