2025 Cougar Bedroom AC control issues
Captain Dan
Vermont
Keystone Cougar
316RLS
36 ft
Hello all, new to this club so there may be a thread going I us couldn't find it.
We purchased a 2025 Cougar 316RLS in November of 2024. We are now in the Florida Keys and its starting to get warmer so we need to solve the bedroom AC noise issue. The unit a Furrion 15K produces nice cold air, the compressor goes on and off without short cycling but the fan seems to only have one output HIGH even though I select medium or low. The noise is crazy, you can't even talk above it. Has anyone out there had similar experience? The Furrion 18K Chill Cube in the living space is awesome and quiet. There is also an occasional E3 error but only occurs with the unit off!! seems odd!!
Thanks for any suggestions Dan
HELLO:
I had this exact issue with my Keystone Outback 298RE. High, but NO Low power on A/C switch.
When I installed a new Digital Control Panel for A/C, I noticed a single blue wire not connected. I had an RV Mobile Tech arrive. He connected all the wires but NOT the Blue wire. The system worked, but NO Low A/C power.
He then stopped........Stated, 'I bet I know what is happening here'.....And connected the Blue wire to a terminal on the control board. Suddenly we had LOW + HIGH power on the A/C unit! The factory failed to hook up the final Blue wire for the rig and sent it out the door.
Typical......
Hope this helps.
[email protected]
Friday
___________
