Musings after first fourteen day trip
newmarokie
southern oklahoma
newmar
Dutch Star 4018
40'
450 hp Cummins
2017 Colorado, 2013 Dodge 1500 quad cab
We just got home today midafternoon. Left out Friday 4-25. Total trip mileage 3100. DEF use ten gallons. Avg. fuel burn 6.9 MPG. Cruise set every day at 68 when limits allowed. I ran a cetane booster on all fill ups but the last tank(I ran out). No appreciable difference on the last tank and the others.
What broke:
The 12v to 110v inverter died on the second day
The master bath fantastic fan will turn on and run for about 10 seconds and close back down. The light on the wall stay on.
The heat pump on the bedroom AC unit is not working. It is new. Iam hoping for an incorrect dip switch setting.
The DW can't open the fridge when going down the road.
Have I ever said the woodfire Ninja is da bomb?
Fantastic fan issue may be a little moisture near the rain switch.
Do you see a dim red light when looking up at the fan? If so, moisture may be the issue which can come from rain, washing the coach, or high humidity from taking a shower. Hope this helps.
I will check that John, thanks
Question, what's with the refrigerator that it won't open? Your AC problem sounds like a dip switch setting is off on the unit. Also, eventually, I would recommend replacing the "fantastic fans" with Maxxair units. Much quieter, more efficient moving air, and you can use them when it's raining without an added cover. I've done all three in our coach and couldn't be happier with them.
Your inverter has a reset button on it. Most likely that has tripped.
Year and model of coach will help us determine exactly where the reset is.
What version of the MAXXAIR did you use?
If it's xantrax inverter I am on my 3rd one, and I had my last one rebuilt by the inverter service center and mounted it between the frame rails close to the original one so that when the next one fails I can hot swap it
Did you wire it to the KIB or bypass the original and just use the remote?
They are wired in hot so I just use the remote. In the bathrooms, I mounted the remote holder on the wall just below the fans. They are SO much quieter in operation, and 10 speeds.
I’m going to be doing this upgrade soon
+1 for the Max Airs with the separate remote for the installs. I did all three ceiling mounted fans in the coach, big difference in noise and air flow while going down the road or stationary.
Three of the four "broke" things from the last trip are resolved. The fantastic fan was just damp and sensored off. As Baron said, the inverter needed reset. I had checked the circuit breaker on the side of the 2812 and it was good. I dug around and found that the system can be reset by holding down the on/off button for fifteen seconds or until the LED comes on and stays on. That fixed that issue. The road latch had become impossible to slide left and right. I got the fridge loose and pulled it out about six inches and took the doors off. I put two brass washers on eah bottom hinge and reassembled. The latch moves easily now. All I lack now is getting up on the roof and checking the dip switches on the bedroom AC.
Before you get on the roof, check the circuit breaker for that ac. Switch it fully off and back on.
I will check, but it is working on AC. You put it on HP and it runs, but it is producing cold air instead warm air.
